enable esrp
enable esrp esrpDomain
Description
Enables ESRP for a named domain.
Syntax Description
esrpDomain Specifies the name of an ESRP domain.
Default
Disabled.
Usage Guidelines
Before you enable an ESRP domain, it must have a domain ID. The ESRP domain ID is determined from one of the following user-configured parameters:
If you do not have a domain ID, you cannot enable ESRP on that domain. A message similar to the following appears:
ERROR: Cannot enable ESRP Domain "esrp1" ; No domain id configured!
If you add an untagged master VLAN to the ESRP domain, make sure to create an ESRP domain ID with the configure esrp domain-id command before you attempt to enable the domain.
The following command enables ESRP for the domain esrp1:
enable esrp esrp1
This command was first available in ExtremeXOS 11.0.
Platform Availability
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.1.1 Licensing Guide document.
